What do you suggest for a engine swap in a Del Sol? I would like to have your input on what engine would be the best depending on hp and running wise thanks.
what about stock cams and 10:1 compression and .9 bar of boost ?blkDOHCsol said:CRVTEC 86mm overbore pistons..type R head...toda VTEC killers ITBs, 13.5:1 compression, etc..250lb tq ALL MOTOR biatch
Steve
thats a lot of boost for 10:1 compression. make sure you get some tuning done or you'll blow it in a week or less.salt said:
Steve
sampson i cant believe you just told that poor guy to get a b18b...get a damn vtec motor dude..dont matter what kind, build it right, and boost it..some guys run pump gas with crazy compression #s but the 13.5 comment was a joke,BOOSTdependent said:Go with b18b w/ boost.![]()
