I just got done with the swap in my teg and its not getting feul, but its turning over. wut could the problem be? thanks
Check the fuel pump to see if it is working. Start checking everything, there isn't to much to the fuel system.
ok thanks i was also told that it could be the ground by the thermostat housing i still have to check on that
I mean check everything out. Fuses, power supplies, ect.... make sure they are getting power.
That was my suggestion as well. Just look over all the ground points.
Discussion Starter #6
yea thanks it was the ground on the thermo housing right when i put that on and turned then key the feul pump went right on :D
Same thing happened to me...try to clean the fuel filter or get a new one (that was my problem) good luck
-yoshi-
