Okay, everyone, here's a post from another thread, getting alot of questions and such about how I did this, so here it is. Good luck all!!
Pics in my gallery. Wish I could attach pics.. :cry
I have a 98 Civic EX and just went from stock lights to blue LED gauges.
It's easy as hell:
You need:
Phillips head screwdriver.(Magnetic helps not to lose screws )
6 - size 74 LED (color of your choice
1 - size 194 LED lights (probly 4 or 8, but I went with a 7440 15 LED (BRIGHT! ) but I had to modify the plug on the 7440 to make it fit.)
take out 2 screws on top of black plastic surrounding gauges.
take out 4 screws around gauges.
Pull gauges out. You will need to unplug the harnesses at the back of the gauge cluster. Just pinch the vertical clip and pull them out.
Now you will see some lights screwed into a plastic backing. Just unscrew the small brown ones, and place your size 74 lights in there. (4 on back, and 2 on the front at the top.)
Then unscrew the large one, replace with your size 194 light, and replace everything.
Reinstall in reverse, and takes about 15 minutes.
Lights (LEDs) can all be found pretty cheap at www.superlumination.com.
GOOD LUCK!! ENJOY YOUR NEW GAUGES!!
reps returned and appreciated...
It's easy as hell:
You need:
