just go with the same size 2.5 dont change unless you are going to turbo the car...if you turbo the car then the axle back is not worth anything...whatever you use just use that same size all the way back for instance turbo use 3 inch all they way back...chaguito said:What size do you guy's recommend for an exhaust center section if you have a 2.5 axle back??????![]()
What other mods do you have?chaguito said:What size do you guy's recommend for an exhaust center section if you have a 2.5 axle back??????![]()
I/H/Axle back,sprokets, fuel pressure riser, denso iridiums, msd cablesv00tecsi said:What other mods do you have?
I'm actually going to leave mine just axcle back...I want to try that with a I/H and CTR cams. Everyone has a cat back, I want to see if the stock 2'' will help me out down low enough to better my 60' times, and give me a better run.
