I think so. plenty of torque and ZC like HP depending on the year engine. I would do it. If you're not trying to make a drag car go for it. It would rip in the city from light to light and merging power.skater431 said:is a f series swap worth the time?
all of which is available through HaSportPSIKOTICsi said:not worth the time....a f-series vtec would be just as good as a b16a or a b18b......but then theres so many issues you have to worry about. you have to worry about the mounts, wiring since the good f-series motors are 94-up, so you-re looking at obd1-2 motors, the transmission.....you are gonna have to try and find a cable f-series tranny.....good luck with that. its just too much of a pain. its more economical and less stressing to go with a b-series motor.
Not the mounts the only H/F series CRX mounts are made by Place racing and they are weld in only.SohcVtecTurboHB said:all of which is available through HaSport![]()
