jDmacCordh22a said:
You can advance or retard your ignition timing by loosening the bolts that hold your distributer and rotating it either way, there is a slide for the bolts to move in. I believe retarding rotates the distributer to the left.
are you going to have a midget in your engine bay retarding it .45 degrees for every lbs of boost?
setting your dizzy timing all the way retarded is just retarded, the car would bog to death when not in boost or low boost. this doesnt work with turbo cars, that is what engine management systems are for.
TSM_Pikachu said:
Hey bone, stock bore and compression......what pistons and rings and rods should i go get and from where?
wiseco pistons w/ stock 8.8:1 CR for the f22 can be found at raceng.com under the raceeng brand, they have them in standard 85mm and 85.5mm over bore. i personally would run the over bores, get the block bored .020 over and honed. since you already spent 500 bucks on pistons and rings might as well make sure your 100k mile old cylinder walls arent scored or warped.
i may look into getting some custom slugs though, w/ a little higher than stock compression though, something like 9.5:1 or around there.
the only major company that makes f22/h23 rods is crower but but they are bank, almost 700 bucks. the next best alternative i have found are importbuilders.com forged H beam f22/h23 rods. i will most likely end up running a set of these they are only $335 and i have heard great things about them. another option is Probe h23 rods, i know of a guy running 460whp on his h23 w/ Probe rods.
should also look into getting new ACL or OEM rod and main bearings, and thrust washers, new uppper and lower gaskets, and timing belt, water pump, and oil pump.
Nissanboy said:
Turbos make your car worse off the line as you have to keep the turbo spooled to get a good launch...
launch off a 2 step
