I need any help and advice on building my 91 accord I wanting to stay with the f22a1 but doing a full teardown machine work and rebuild also doing all suspension and convert the rear to disc brakes
What kind of advice do you need and what rebuild are you planning to do? I'm currently working on my car as well, so I might be able to help. I'm checking 4wheelonline for their available suspension lift kit since I'm planning to make adjustments to give way for the winter tires that I want to install.
I planning to do the head and block going to machine wanting to replace cams pistons crank and and anything else that needs it but not sure wat exactly should I go for with the compression ratio
Ps. I found a set of megan racing coilovers for my accord for about 850
