Hello guys,
I have a 1997 (5th generation) Honda Prelude with chassis code BB7 (4WS) and an F22B engine with the SportShift transmission. A few days ago the cambelt snapped and even though we have not opened the engine to see the extent of the trouble, we measured the compression of the cylinders and two of them provide no compression at all which probably means the pistons have holes in them
I am therefore looking to find a used engine for the car and I was wondering, since I will be replacing the engine, why not go for the more powerful H22A VTEC motor instead of the F22B the car originaly came with.
The question is whether it is a straight swap or if modifications are needed and to what extent with regards to the following items:
Gearbox
Engine mounts
ECU
Cooling
Electrical wiring
Electronics
Sensors
Anything else to think about?
Let me know if you need any further information in order to be able to answer.
Any input or reccomendation will be greatly appreciated!
Thanks!
Gearbox
Engine mounts
ECU
Cooling
Electrical wiring
Electronics
Sensors
Thanks!
