So i have a 97 Accord LX and it has the F22B2 Non-Vtec motor and id like to swap the entire F22B1 motor because there's more aftermarket support for it and all i know is that ill need an ecu so i have questions starting with
What else will i need to make this swap happen?
Can i bolt it to my 5 speed manual F22B2 tranny?
And last does it use the same motor mounts as the F22B2
the f22b1 will drop right in since you have v-tec i would install new clutch and pressure plate t.o.bearing reface the flywheel pick -up ecu for a 5 speed if you can find a complete ex pull the ecu then the wiring harness that way its plug and play GOOD LUCK , DADDY DAVE .[ HALF CIVIC WILL RUN ]
