1 - 10 of 10 Posts
do any of you guys had problems with your factory exhaust? my exhaust sounds like its' been chopped in half! i took at a look at it and saw no cracking.. however it does sound like its coming from that cat. I also have a friend who is experiencing the same problem.
I really don't think its a leak. It sorta sounds like an aftermarket exhaust, but with rattles.
Its a 97. I think a lot of the 5 gen accords have the same problem with the factory exhaust.. cause i always hear it.
i got the same problem except i have aftermarket exhaust system i look at it and it was the res so igot a guy to rip it outa there and put piping in it's place it sounds better an louder but you could easily just take some kauk type stuff at lowes called great stuff and just patch it up if it is a hole thats what i did until i got my res removed
Discussion Starter · #6 ·
yeah i check all the brackets and everything.. i can pin point the location where the crappy noise is coming from.. and it sounds like its coming from the cat. but thanks shagysteve i'll check it out.
prob. a leak .. I just took my exhaust off to replace w. a tanabe system and the OE one was all rusted and was pretty leaky near the center flex section. if you have that farting noise .. its prob. a leak around the header / cat.
Discussion Starter · #9 ·
haha i think i HAD the RPM buzz problem.. but now my exhaust sounds like crap at any RPM. well thanks for everybodys' help.. this is my beater so theres not use in replacing exhaust and headers with aftermarket parts.. i'll probably just go to an exhaust shop and see if they can fix the prob..
I had the same problem on my 94 I resolved the problem by removing my heat shields. there bolted on around the cat. for extra protection and rub against the metal brace causing a big vibration! The cat. already has protection around it so i just took them off.
1 - 10 of 10 Posts
