What's up guys I own a 04 Honda Civic Ex and as most of you might already know that it has disc brakes up front and drums in the back. I'm going to be dropping in a rsx type s motor into it and what I wanted to know is if there is a disc brake convertion kit for hondas' that have drums in the rear? After I drop that motor in i'm probably going to have to have better braking capabilities. Unless any of you guys have a better idea i would appreciate your inputs.
thanks
The rear brakes hardly do any of the work. If you really want better braking, you would concentrate on the fronts. If you didn't know this, I hope you are not the one doing the swap because maybe you need to read up a little before you dive into something that extensive. Props on the motor choice, need pictures before I believe you though.
