I am in the process of lowering my suspension and my spindle bolt on one of my rear struts is stuck. Also the retainer bolts for the upper control arm on the other side are stuck(I'm installing an Ingalls camber kit as well and it replaces the upper control arms).
I've had no trouble with any of the suspension bolts in the front. I read that torching them with a little benzomatic torch helps and I tried it (it did help on some), but it hasn't worked on these three bolts. Any other tips or tricks for removing frozen bolts?
