Means of Contact: send me a pm, or you can text me at 8FIVE8-3TWO4-4SIX72
The following parts are from my 2009 Civic Si, please feel free to contact me with any questions
▄HASPORT motor mounts - 70a "RACE", The 2 front mounts that are visible in the engine bay: I had them chrome plated... the rear mount is not plated-- Complete set of mounts and brackets $370
▄BOOMBA red front motor mount $60
▄INJECTOR DYNAMICS 1000cc injectors $340 + PnP adapter clips $40
▄HYBRID RACING (gold) fuel rail with push in efi fitting $115
▄SwiftRacingTechnologies Precision Billet 6262 TURBO
▄Stainless steel braided oil lines
▄High flow Intake (3" piping and filter)
▄SRT front mount intercooler with garret core
▄Hoses, tubing, nuts, bolts, couplers, bands, fittings
▄ALMOST COMPLETE FUEL RETURN SYSTEM: (Aeromotive fuel pressure regulator, fuel lines, nuts, bolts, fittings, Injector Dynamics 1000cc injectors, Hybrid racing fuel rail, )
▄Custom full 3" exhaust (straight pipe, resonator, midpipe, vibrant muffler)
<<<The exhaust is basically one long piece, starting from where the test pipe leaves off... After the test pipe which directly bolts on, the exhaust goes like this: RESONATOR=MIDPIPE=== X detatched muffler (can easily be reconnected using a $10 exhaust coupler, or get it welded on. There are numerous methods of reconnecting the muffler, most of which are very low cost.) >>>
▄Downpipe with flex section
▄Dumptube
▄Turbo manifold
▄Hondata boost solenoid
▄Tial 50mm Q-blow off valve
▄Tial 44mm MVS v-banded wastegate
while on the car, turbo running smooth as silk, some of the piping has dents, i will take better pics of everything just ask : car was making 450+hp on E85 $4150
▄INTAKE MANIFOLD COVER $35
▄JDM black oil dip stick $
▄OIL DIP STICK painted black make offer
▄H BRACE $65obo
▄AEM digital BOOST gauge $100
▄AEM digital UEGO wideband gauge $120
▄PROSPORT HALO SERIES digital exhaust gas temp gauge $50 w/out sensor
▄A-PILLAR GAGE POD wrapped in suede (its a little dirty in the pictures) run a lint roller over it, and it will be good as new! $55
OR
▄$315 for all 3 gauges and the suede wrapped 3 port gauge pod
▄stock 09 civic si rear sway bar w/brackets
