1 - 20 of 20 Posts
PRICES ARE FOR PICKUP. I can ship.
96-98 oem front bumper $20 pick up has tear on both side
96-00 hb oem rear bumper $20. need repainting
96-98 oem hb tails $25 each side
96-00 hb/ or coupe carpet $25. needs some cleaning
96-00 firewall. cut it and use it other places also to reduce noise $25
96-98 oem grille w/ mesh $20
99-00 4dr grille. will fit coupe also $25
brake boot $10
new brake lever $10
socket panel $25
aftermarket exhaust $20
Discussion Starter · #2 ·
dx spoiler $25
defrost button 96-98 console $6
hazard button 96-98 console $6
honda tape deck. better than block off plate $25
96-00 kickpanels $15 each
96-00 side dash panels $15 each
rear view mirror $20
speaker panel $20 each. both for $35
tool box liner $10
Discussion Starter · #4 ·
h center caps $20
mb quarts headphones. brand new $25
99-00 oem front bumper. no lower grille $25
front oem block off plate. if you removed your a/c $20
clutch reservior w/ cap $20
del sol sliders. $25
96-00 power mirror seals $20
din pocket $20
ground loop isolator. eliminate ground noise $11
same same. $11
clutch master cylinder
I see you have the clutch resevoir for sale, but do you have the master cylinder? I bought a brand new one about 11,000 miles ago and it is already shot. If thats all I'm gonna get out of a new one I figure i should look for a used one
1 - 20 of 20 Posts
