1 - 20 of 20 Posts
these are ready to go correct that fuel line will bolt up to our cars i just need the custom manifold for it correct.
Discussion Starter · #10 ·
yes they are ready to go beside the manifold. i believe that you can use the stock honda fuel line since it will be longer. depends also if you choose to use the stock honda injector location of the one for the cbr injectors. http://www.**********.com/zerothread?id=1149532 change the **** to honda tech with a dash in between to follow link. this guy recomends the stock honda manifold injector location. that way you can use your stock or aftermarket fuel rail and fpr. also the injector holes where they would be on the ITBS can be used to power the brake booster. Read the link in this post, these are with gsxr itbs which require a little more work and is less plug and play. While the ones im selling use all honda sensors.
pmd you
1 - 20 of 20 Posts
