1- ok, no more need for #1
2- as a one nozzle setup yes (but I need help on the install of the fuel side stuff, and I don't have anyone qualified for this) as a DP system, not really, if at all
3- what engine components, what suspension components, for good improvements and comp price.
4- good to see we got that one cleared up
5- I realize that, but I do not really need better suspension for a 50 shot (forgot to mention, I'll be using a progressive controller to save my auto tranny from as much shock and strain) with a progressive controller to smoothly bring in the power.
6- I'll get my butt handed to me with the tires and suspension too, more than likely. This isn't about being able to say what my hp is, it for if I'm neck and neck with someone, I'll be able to give myself a little bit of a boost to give me the lead. I don't plan on actually doing the DP setup now, I can't put as much power as I want through it, and I don't want to put a lot of money into suspension and engine internals on a car that I plan on getting rid of after college.
So, here's where I stand:
Going conventional dry shot of 50 hp. Going to use a progressive controller to bring it in as well as a WOT switch, MSD window switch, an arming switch, and a push-button switch for the actual spray control (I know this is a lot of electrical, but I want protection from spraying below 3000ish rpms and over 6000ish rpms, protection from spraying below WOT, and I want ultimate control over when it is sprayed) One question, does the 96 accord have a throttle position wire (tells the ECU what percent the throttle is)?
