If your fuel rail spacing is like that of a D16A6, then it should be about 85mm between injectors (centerline of injector to next injector). If this is the case, then you can use the Venom fuel rail. The cool thing about the Venom one is they have adjustable slders that mount to the intake. I am using one for a D16A6 on my ZC engine and my D16A1 engine in my Integra. The 1.8L engine has I believe 87mm spacing on the rail. Hope this helps....
