Can you explain why??....I've seen set ups w/out turbos that have the fuel rail.....just curious.....thanks2000 EBP Si said:Well it depends on what you future plans for your car are. If you are planning on adding a turbo or a supercharger then I it would be a good investment. If you are planning keeping it basic with just I/H/E it would just be a waste.
Aftermarket fuel rails are larger than stock and allow you flow more fuel to your fuel injectors because of the larger internal diameter (as long as your fuel pump can supply the extra fuel). This larger bore also dampens the back pulse created (if you are cruising along and then punch the gas pedal) by oversized injectors in high-output applications. On a stock engine, most people do it for show but some people claim it will dampen the back pulse and the engine has more 'punch'.HEK said:
So far these reasons are favorable to any set up.....right??...a guy that was training in the building next door has one on his stock Si, one thing he said about it was that for some reason he had to warm up his ride2000 EBP Si said:
It is also easier to add a fuel pres. gague or N2O, like lazer stated.
