Ok well.....turbos are great because of their top end and crazy power....but they tend to lag in the low end because the exhaust gasses need to spool the turbine up before the motor sees boost.
So, turbo upside = big power, mainly mid-top end
turbo downside = laggy in low RPMs (unless you get a tiny turbo that spools fast, but they will lose power up top....there are ball bearing turbos that spool up fast and give plenty of top end but these are considerably more expensive)
As for superchargers.....the most common one for our hondas are roots type blowers (Jackson Racing Supercharger).....these are blowers that are driven by the crank pulley (like accessories such as power steering, alternator, A/C)......the main reason us honda people like JRSC's is because it makes our little 4 cylinders feel like v8's....meaning it has very linear power and has full boost by like 1500 rpm or so. It gives our little torqueless bitch motors the low end that they lack....but it also gives a nice linear powerband so it doesn't die off in the high end. The only drawback to these is that they tend to not make as much power because they just don't flow as much as a turbo, AND because they put parasitic lag on the motor. (Ever turned on the A/C and felt the car's power decrease?) It's being driven by the crank so a decent amount of power is lost in driving the supercharger.
So...supercharger upside = low end and nice linear powerband
supercharger downside = not as much peak power...and intake temps tend to be pretty hot because it's not the most efficient blower and because of the lack of an intercooler.
As for the Vortech Supercharger....it's not a roots type blower so it doesn't have that low end. It uses a turbine just like a turbo, except the turbine is driven off the crank. So you not only see parasitic drag on the motor, but turbo lag as well! Not to mention the price of it!
IMO it's way overpriced.
I"m budgeting about 2500 give or take 300 for my turbo setup and that's going to be with a ball bearing turbo, intercooler, tuning, and everything, the whole kit and caboodle.
And in the end I hope to be making 270-280 whp with decent spool times too, and I've got a b16.
