k..... ive just wired my car with 4ga and i was wondering what size fuse i needed if i was going to run the bp1200.1 or the bp600.1? thx. ....... i had a 80 amp one but it didnt work with my friends 300 watt amp.... wierd, is the fuse broken? thx.
1200mk said:hmm. ... the 1200 uses 3 X40a fuses the 600 uses 2X30a fuses.... so what do i use?
how many times do i hae to say wattage doesnt mean shit when it comes to your fuse size every amp gives u a differnt rating,if one of his amps uses 3 40 amp fuses thats 120 amps from 1 amp so yes a 60 amp fuse will blow right there and if the other amp 2 30 amp fuses thats 60 amps so 120 amps plus 60 amps = 180 amps so if u dont think a 60 amp fuse will blow put one in and turn up the system and watch it blowacuradriva said:
120A for the 1200.1 or a 60A fuse for the 600.1. dont get a 180 A breaker. a 60 A fuse shouldn't blow from a 300 watt amp. your friend must have a short or a bad amp.
APOCALYPSE...why are you jumping all over him?!?! He gave the same answer as you, 120A for the 1200 and 60A for the 600! What gives? He said the 1200 OR the 600, not both....sheeshAPOCALYPSE said:
my bad i read it wrong guess thats what happens when our half asleeprcurley55 said:
