Damn dude! I always get that answerMrMike said:10.5:1 is pretty high for 8lbs of SUPERCHARGED boost. the highest u could probably go is 9.5:1. only time high compression is combined with boost is in low boost and high RPMs where the boost is just used to help fill the cylinders at very high rpms.
That depends. Do you want to retard timing about 20 degrees? I've heard of people putting 11 psi turbos on the S2000, but they had to retard timing something severe.skibbs said:Uh... what about the Comptech supercharger for the S2000? Jackson Racing SC for the B18C5? That is NOT too high of a compression ratio for a supercharger at 8 lbs.
Just thought it was slightly appropriate with all the terrorist attacks latelyGayHatch said:ahahaha G and F'n roses.......your sig killed me sunder.....my friend sings that song all the time
