okay do i figured out the only way i can run the P28 ECU is to locate the Idle Air Control Valve and clip the ground wire from the harness and groud it to the throttle body or any suitable ground. I have a 2001 accord with the F23 and im guessing that i have to put the car on a lift to get to it cause i cant see annnnything from uptop. need help ASAP
cutting away 1 wire doesnt make it the same as an obd1 2 wire sensor. you gotta wire in an obd1 iacv and figure out a way to mount it back into the intake manifold, the obd1 doesnt fit the same as the obd2.
theres a wiring diagram here
http://honda - tech.com/zerothread?id=1225468 (remove the spaces)
