1 - 10 of 10 Posts
This is my first post here in this forum..
I have to connect a 50 foot telephone cable to connect to the internet becasue the telephone outlet in the garage where my computer is does not work..
In addition to this.. i will be adding a new computer in my room.. so two computers need to share the same connections..
I'm going wireless.. so my questions are:
1 - How do i prevent or how likely am i to run into someone "stealing" my connection? And how do i avoid/block that problem?
2 - What brand of wireless router should i purchase? I'm going to Best Buy within the next 1 1/2 hour so i hope someone could help me there.. and if brand doesn't matter tell me that too
Thank you for your responses
Most if not all wireless routers have an encryption option...just pick a password and the network will be encrypted and protected from unwanted intruders.
And for your purposes, a normal D-link will be fine.
JUST STAY AWAY FROM BELKIN! THEY ARE THE DEVIL!
Thanks you
:) most secure way is to use mac address encrpytion, weach piece of hardware u buy has a mac address so only 2 of ur computer will be able to connect i have this on my 3 computers at home and i had never had no problems, also having a admin password or else someon will go in and block out of ur own connection :)
This is the exact method I'm using. Each computer has a MAC Address (sort of like an ID number--I think of it this way), and you can specifically choose to allow which MAC addresses to connect to the router. Other people would see it as "Wow, this is unsecure! I can connect/leech off!" WRONG--they lose :). If you're computer is not on the list, it won't allow you to connect. Also--yes, change the default admin password.
For example my neighbors had a Linksys router, since I'm all Linksys, I know the default address/admin passwords. Sometimes I leech, but not for too long... :ninja
As far as being more secure, I'm not sure if that's certainly true, but it works for me! :).
EDIT: Way off topic... Does anyone know what font is used on those USERBARS? Thanks...
Mac addresses can be stolen off of wireless communication in about 30 minutes of dedicated packet sniffing. So can Wep128. WPA and WPA2 are the only "secure" methods of securing a wireless network at this point. And even then... they can be broken.
my wireless doesnt have that. when i log on with my laptop and just click internet explorer.
wats the password? should i set mine? i live in a house. how far does the wireless connection work?
linksys supports wep/wpa encryption as well as mac address filtering.
I'm using an apple airport extreme and airport express for my wireless. Will be installing a d-link 524 or 542 at a friends place in a few days.
1 - 10 of 10 Posts
