I am currently looking to purchase a set of pistons for my b16.Im runnin eagle h-beams and im not 2 sure as to what compression ratio 2 run.I have a b16a and am using a gsr head so......I wanna be able to run at most 12 psi.I was thinkin leavin stock compression.What do you think?My idea was srp 9:9:1 with the gsr head is about 10:2 then add a thicker gasket
dont get srp pistons unless you want to have a blown up engine. those pistons are brittle nad will break.
id recomned going with around 9.5:1, much more and you will have to goto race gas too soon. remember, the lower the compression you run the more boost and power you can make on pump gas.
