Just borrowed a G-tech and want to tune up my car. :D I can't go to the closest dyno because is really far. :mad:
Here is what i got capable of tunning
variable fuel pressure regulator
cam sprockets
timming
Field SFC VTEC controller
Any baseline where to start off???
Any good tips on tunning????????
Thanks
:gundam1: :megam:
This should be the correct order in tuning:
1. Find the Best VTEC X-over Point
2. Cam Gear Tune
3. Fuel Map Tune
4. Tune the ignition timing last.
Make sure you get a tune-up...good ignition compnents ie; spark plugs,cap,etc.
Good luck
My car has a good tune up.....Denso Iridiums, Mobil 1, MSD cables and futurely external MSD Blaster 2.:D
Thanks for the advice
a g-tech is NOT something you want to use for tuning an engine.
You need a controlled environment to test an engine, not an open street.
