1) Is there any additional hardware / accessiories required when using Blistein HD shocks?
2) What is wrench for that they always advertise?
I'm thinking to turn the adjustable spring rate
3) Does anything cover the threaded sleeve part?
I can't imagine it staying clean / free of debris. Seems like it would really be a pain to adjust if dirt and $hit got in the threads
4) Will it be ok to ride around with the spring set on a lower setting / slammed look?
I imagine the quality in ride will just decrease as you go lower. Any first hand experience with the different levels?
5) Last any e-mail addresses to write for technical support at Ground Control?
All I found was a long distance #. I would much rather go through e-mail so I a) have it on paper what they say b) can post the exact messages here!
6) Do I have to cut my bumpstops?
Below is a pic of the coilover:
