hi im new to the forums. i own a 98 civic that i am swapping a gsr motor into. i currently have the motor, trans, and the ecu. i want to no a complete list of everything i need in order to complete the swap. from what i know now i need shift linkage, axles, obd2 to obd1 adaptor, and 99-00si motor mounts but i heard a need a t bracket is this true? thanks
so i'm assuming the engine/ecu is obd1 thats why your getting the obd1 conversion harness.
you may want to get the engine wiring harness so you don't have to splice up wires. and make sure you get the half shaft for the tranny if it doesn't have it with it. you pretty much named what you need other than that.
