I recently had my gsr motor built, anyway long story short couldnt get it started realzed that the guy who put my motor together didnt kno how to set the timing with adj. cam gears, so the timing was off. Since the timing was off my valves bent. So car started up but back fired and had no power. Anyways i set it on tdc removed the timing belt, valve cover, cams, basically everything to take the head off. So now heres my problem my fathers friend who rebuilt his integra cylinder head did my valves, i replaced my valves with nitric coated supertech valves. When i got the head back i put everythign back the exact way i took it off. Double checked eveyrthing, timing even replaced the distributer, new spark plugs. the car will not start, i am soo frustrated because ive literally checked and double checked eveyrthing it could be, im gettin spark im getting fuel and from tryin to start the car soo many times with it not starting i believ ive flooded it because the oil its really watery feeling and smells liek gas so im changing the oil. now heres my question. When i orignally bent my valves i knew they had bent because before i redid the timing the right way i felt the valves hit and thats when i knew the timign was off. so like i said i redid it and the car fired right up, now after i put the head back on with the new valves i set the mtor at tdc for #1 and i rotated both of the cams with the timign belt off and they go around and around not hitting, is it possible the car wont start because the valves need to be adjusted bad? thats the only thing i can think off since the piston is all the way up and the valves dont touch it at all. plus when i look at when im rotating the cam when i see it push down the rocker arms in sets of 2 per cylinder one looks like it goes further down then the one next to it liek thye both go down the same time but one seems to go down further. Can someone pleas ehelp me out ive been waiting to drive my car for over a year (Money problmes) and finally after waiting all this time and gettin the money to fix it now ti wont start im at my wits end i dont kno anymore someone please help me!!!!!!!
