1 - 11 of 11 Posts
Time for another GT3 Challenge! :D
GT3 Challenge for week 3:
RULES:
- You may not use hybrids or GameShark modified cars.
- You may not use cars from your garage (for this challenge).
- You may not cut corners, go off the grass with all 4 wheels, or wallride.
- You may remove the ASM (Active Stability Management) and the TCS (Traction Control System) from your vehicle if you'd like.
Game setup:
- Select "Arcade Mode" from the main menu then choose "Free Run".
Track:
- Laguna Seca (tarmac)
NOTE: for this track you will need to beat all of the "Area A" tracks either in easy, normal, or hard mode to progress to "Area B" where this track is located.
Vehicle:
- Class S -> Viper GTSR Team ORECA
- Anykind of transmission -> Auto / Manual
- Anykind of suspension setup -> Racing / Drift
You have unlimited amounts of laps to run since it is Free Run mode. Record your best lap time and submit it here. Again PLEASE NO WALLRIDING! If possible, *please* post a screenshot of your time to ensure accuracy. You have until next Wednesday midnight (11/19) to submit your records!
Good luck! :)
(Don't forget to post/update the link in your signatures. Thanks!)
1'17.67, thats all i could pull off... not to good but o well
1'16.498 after 25 laps... i think i could cut another second off since i hit 1'16 a bunch of times, and still wasnt satisfied with the corkscrew turn.:) TCS and ASM turned OFF of course.
OK...I wasn't too involved in the last challenge but, I decided I'll give this one a shot.
Survey Says.....
1'14.089
1 - 11 of 11 Posts
