Full health
While playing a game, press R2(2), L1, R1, Left, Down, Right, Up, Left, Down, Right, Up. If you entered the code correctly, a message will appear. If your vehicle is on fire, enable the "Full health" code to extinguish it.
Full armor
While playing a game, press R2(2), L1, L2, Left, Down, Right, Up, Left, Down, Right, Up.
All weapons
While playing a game, press R2(2), L1, R2, Left, Down, Right, Up, Left, Down, Right, Up. Repeat this code for more ammunition
Infinite ammunition
To get unlimited ammunition, enable the "All weapons" code continuously until whatever you want is at 9999 shots. The next time your clip runs out, it will reload automatically but the magazine (9999) will stay the same.
Extra money
While playing a game, press R2(2), L1, L1, Left, Down, Right, Up, Left, Down, Right, Up.
Lower wanted level
While playing a game, press R2(2), L1, R2, Up, Down, Up, Down, Up, Down. If you entered the code correctly, a message will appear. Note: Saving the game will make the effects of this code permanent.
Higher wanted level
While playing a game, press R2(2), L1, R2, Left, Right, Left, Right, Left. If you entered the code correctly, a message will appear. Note: Saving the game will make the effects of this code permanent.
Flying (Dodo) car
While playing a game, press Right, R2, Circle, R1, L2, Down, L1, R1. Accelerate and press Up to fly.
Tank (Rhino)
While playing a game, press Circle(6), R1, L2, L1, Triangle, Circle, Triangle. If you entered the code correctly, a message will appear. The tank will appear in front of you. This may be repeated as many times as needed.
Destroy all cars
While playing a game, press L2, R2, L1, R1, L2, R2, Triangle, Square, Circle, Triangle, L2, L1. If you entered the code correctly, a message will appear.
Better driving skills
While playing a game, press R1, L1, R2, L1, Left, R1(2), Triangle. If you entered the code correctly, a message will appear. Press L3 or R3 to jump while driving. Note: Saving the game will make it so your car will never tip. Also every car will have hydraulics which will enable it jump 15 feet in the air over other cars.
Increased gore
While playing a game, press Square, L1, Circle, Down, L1, R1, Triangle, Right, L1, X. If you entered the code correctly, a message will appear. Note: Saving the game will make the effects of this code permanent.
Overcast skies
While playing a game, press L1, L2, R1, R2(2), R1, L2, Square. If you entered the code correctly, a message will appear.
Rain
While playing a game, press L1, L2, R1, R2(2), R1, L2, Circle. If you entered the code correctly, a message will appear.
Normal weather
While playing a game, press L1, L2, R1, R2(2), R1, L2, Triangle. If you entered the code correctly, a message will appear.
Speed up time
While playing a game, press Circle(3), Square(5), L1, Triangle, Circle, Triangle.
Alternate costumes
While playing a game, press Right, Down, Left, Up, L1, L2, Up, Left, Down, Right.
Pedestrians riot
While playing a game, press Down, Up, Left, Up, X, R1, R2, L2, L1. Note: Saving the game will make the effects of this code permanent.
Pedestrians attack
While playing a game, press Down, Up, Left, Up, X, R1, R2, L1, L2. If you entered the code correctly, a message will appear. Note: Saving the game will make the effects of this code permanent.
All pedestrians have weapons
While playing a game, press R2, R1, Triangle, X, L2, L1, Up, Down. If you entered the code correctly, a message will appear. Some pedestrians will throw bombs or shoot at you if you steal their car. Note: Saving the game will make the effects of this code permanent.
Invisible cars
While playing a game, press L1(2), Square, R2, Triangle, L1, Triangle. If you entered the code correctly, a message will appear. Only your vehicle's wheels will be visible.
Faster game play
While playing a game, press Triangle, Up, Right, Down, Square, R1, R2. If you entered the code correctly, a message will appear.
Slower game play
While playing a game, press Triangle, Up, Right, Down, Square, L1, L2. If you entered the code correctly, a message will appear.
Infinite Flamethrowers
Put out twenty fires on each of the three islands (about sixty total) to get unlimited Flamethrowers at your hideout. Note: This does not have to be done all at once.
Infinite Health icons
Save fifty people on paramedic missions to get unlimited health icons at your hideout. Note: This does not have to be done all at once.
Infinite Adrenaline Pills
Save fifty people on paramedic missions to get unlimited Adrenaline Pills at your hideout. Note: This does not have to be done all at once.
Police bribe
Get 45 kills in vigilante mode to unlock a police bribe that is available at your hideout.
Faster taxis
Get 100 fares in cab mode to unlock faster taxis available at Borgnine in Harwood in Portland.
Bonus Buggy
Successfully complete the Mafia missions in story mode to unlock the Buggy. Return to Portland and go to the Diablo parking lot (where the mission phone is located) between 19:00 to 24:00 to find the same Buggy glimpsed in Joey's garage from the Mafia mission. It will appear in the same location and change color each time.
Easy "infinite" run
To continue to run at a fast pace without fatigue, just tap X instead of holding it down. This helps when trying to give your character "exercise" so that he can run for longer periods of time as well.
Stealing police cars
To easily steal police cars, press Triangle at the drivers' side door. Then, as the policeman gets out, go to the passenger side and get in.
Use cars as a bomb
If you need a big bomb and you do not have the money for Eightball, smash your car into things and use it as a bomb on wheels when it starts to burn -- but make sure you get out of the car before it explodes.
Getting guns
Go by Toni's place to find an alleyway where an Uzi is located. Go near the mob car on the ledge in the other nearby alley -- you can go between two buildings and find an AK47-like rifle and some armor.
Hidden packages
When you see the Rockstar billboard, there are usually some items nearby. On the three islands, hidden packages are usually found near the billboards. For every ten hidden packages you find, you gain access to a new weapon located at your hideout, free of charge.
Programmer message
Go to the parking lot where you had to take out the men with bombs on their chests. Use the Dodo or a pile of cars to get on the other side of the wall that surrounds the area. Once in there, look for a poster with a secret message.
Regain health
Car jack any vehicle and drive up to a prostitute walking the streets. Stop and let her approach the car, after a few seconds of talking, she will get in. Drive to a remote area where there are not any cops around (a good place is in your hideout). Stop the car, but do not get out. After about two seconds, the car will start rocking back and forth. You will recover approximately 40 to 50 points of health. When it is over, she will exit the car and walk away, but not before she charges you a fee. At this point you can beat her up and take back the money you just paid her. Note: The prostitute will fight back when you try to take your money back. If for any reason you both have to exit the car before it starts rocking, you will still be charged a fee (beat her up to take it back). You cannot do this with the same prostitute twice in one night -- you can however, pick up another prostitute and recover more health. Even though the maximum amount of health points is 100 when you start the game, it increases to 125 after the encounter and remains that way.
Get to Staunton Island early
Use the following trick to get to Staunton Island before the bridge is fixed and before the subway is open. Go to the bridge to Staunton Island. Go past where the blockage cones are located, to basically be on the bridge. Enable the "Dodo car" code (press Right, R2, Circle, R1, L2, Down, L1, R1), then the "Tank" code (press Circle(6), R1, L2, L1, Triangle, Circle, Triangle). Make sure you are all the way back to get enough room to take off using the tank (as a plane). Start firing the cannon backwards and accelerate. Keep firing the cannon backwards, and just as you get to the edge where the bridge has been broken, you will take off. Try and get back on the ground. If done correctly, you will now be on Staunton Island and when you cross the bridge, the "Welcome To Staunton Island" screen will appear. Note: You can use nearly any car, but the tank has a better ability to fly higher.
Flying Dodo car
Take the Dodo to the very end of the runway. Turn it around so its facing away from the edge. Hold X to build up momentum, while holding Up. Once you get enough speed, quickly hold Down. Once airborne, use normal controls to level out the car. Note: The small wings make extended flight extremely difficult, if not impossible.
continued - >
