1 - 8 of 8 Posts
Once the car is warmed up, the car lags. Check engine light is on all the time, which is code 05. I believe that is the map sensor code. Did the test on the map sensor and came up good, swaped map sensor and the check engine light is still on. I was wondering if there is anything else that can make the code come up 05. Thanks!
I believe that it's not the wiring. We have already tested the wires for the map sensor itself and also the other end of the connecter. Everything checked out fine. The engine was running fine, it had vtec and i believe the secondary intake was also working too. I was wondering if the secondary intake valve could make the car lag for some sort of reason? Could it be opening up at the wrong time? Please reply. Thanks!
1 - 8 of 8 Posts
