I have a 95 h22 and i have je pistons 10:1, eagle rods, and darton sleeve kit. What size shot should i be able to run without a problem. I was looking at a 100-150. Does anyone think this could be a problem. Also does anyone recomend any certain system. I was looking into nx.
You can run 100-125 all the time, but never with a fogger kit, a DP is a must in your situation. Otherwise if you get a fogger then you wasted the cash on the sleeves and stuff.....besides foggers only go to 75 shots....safely that is....
upgrade the fuel pump, ingintion system , and clutch. Then buy a DP system or plate system and spray a 150 shot and you'll be in the low 13's maybe even mid 12's with some bomb ass driving.
:D good luck
