shifter cables
You are going to need to cut a hole about 8 inches or so infront of the hole where you mount the shifter assembly to run the cables up through the hole and to the assembly. what are you using to cover the hole (on the underside of car) where u mount the new shifter?
I think the consolecovers the hole when your done...
I think i read this in the sept 01' issue of SCC it has a great article on that specific swap.(WHICH I am currently doing)
