1 - 8 of 8 Posts
the search function is an ingenious way of finding this kind of info out. not only here but on yahoo or google as well
its just like doing a b swap, except its a tighter fit and you'll need custom axles. you'll need a mount kit, axles, tranny, ecu.... mounts and axles hasport makes. they also have good tech info on their site
you and i are in the same boat, im also planning on doing an h22 in my coupe, so far only real problems i've come across is the motor weighs alot more so there's gonna be some crazy understeer, need ac & power steer relocation kits unless you don't want either of them, drive axles need to be changed, different motor mount brackets, and whatever else there is that i have yet to come across. good luck :)
1 - 8 of 8 Posts
