Just finshed my H22a conversion. Having a Bad problem now. Car starts but have a prob. here it is.
ECU
throughs up the code for the fuse assembly is gone I switched it with another accord my friend owns. Still same problem.
When driving the car it backfires close around redline. Now for some odd reasons before redline. It will start to die out i adjusted idle just to keep it moving. Checked timing looks fine. I added the external coil/ first time I used a MSD SS coil, had this problem. Then I added stock accord coil same problem. I have new plugs and wires. And gettin a good spark. I have no clue what else to try. Any input would be sweet.
F13
I will try to add a clip soon as i can of what it does
ECU
F13
