Just stumbled across this board today looking up info on swappin in the h22. The situation is that I'm using the stock h23 wiring harness (supposedly makes the install easier), JDM ECU, injectors as well as intake. I've run into a bit of a problem in hooking up the vtec solenoid, my problem being I dont know what to do. I've been told it takes three wires to do: 1.solenoid to the ECU, 2. pick up (?) 3.engage wire (?)
If anyone could help me with a link or advice on how to wire up the solenoid that would be great.
Super Ban-Finger Mod
http://www.superhonda.com/forum/showthread.php?t=164067
The VTEC oil pressure switch wiring will already exist on the Accord EX’s, but the rest of us need to add the circuit., The plug from the h22a and its light blue wire gets routed to pin D6 on the ecu. The black/red wire form the switch goes to ground.
To hookup the VTEC solenoid, connect its green/yellow to pin A4 on the ECU.
it's very similar to doing a swap into an accord.
Discussion Starter · #4 ·
Does anyone know how to wire in the vtec solenoid to a chassis that came with 2.3L DOHC I keep hearing three wires but which wires are they? And where on the JDM ECU do they connect to, I'm using the stock wiring harness as well which is supposed to make things easier. So far this has been my onl stumbling block.
