i was messing with "source SDK" which came with hl2 and i cant figure it out for sh!t.
It would be nice if someone came out with a map creator that worked the same way as the sims where you build houses and stuff.
simple point and click map creating rather that compile this and mold that. its like another language. :p
does anyone know of a simple map creator for hl2/css?
Discussion Starter #4
thanks for the links... those sites helped me a lot but only after i found the help menu on Hammer. theres a tutorial that goes through some of the basic stuff you need to know to get started on creating maps. i'm far from pro but im working on a map now. if i keep at it the way i have been, i should be done with a test map by the end of february. by test map i mean just one with crappy textures and crappy lighting for play testing. once it's tested and no any leaks are plugged... ill apply the prettyfication.
the only thing im having trouble with is the cracking glass but ill get it.
one of my friends suggested i make a map of the mall @ millenia but that would take a whole development team months ... im only one guy :p
