So I have a 98 ex. I'm using the Hasport EKK2 mount kits. I swapped in a ps crossmember and rack from an ITR. Everything went fine, and then I try to put the rear bracket in place. Clink... Won't fit. The bracket hits the p/s line.
When you try to put it in place, the holes are misaligned by about 8mm. So, add some clearance around the line, and I would have to grind a notch at least a 1/2 inch into the bracket to clear the line. I did some digging and found that is exactly what some people have done to address this problem :
http://sromagazine.com/prima/displayimage.php?album=43&pos=4
Of course I found this lovely problem on Friday evening about 15 minutes after Hasport had closed for the weekend....
Anyways, here are my pics...
