i have a 95 civic hatchback si(comes with four wheel disc brakes). i also have b18c in my car and it doesn't seem to stop the same anymore. i wanted to get a gsr brake conversion for the front but i was reading in some older posts that the discs i have on my car right now are the same size as the gsr front brakes. is that true? i thought that only the rear discs and calipers were the same size. i thought the front brakes of the integra had bigger discs and bigger calipers. am i mistaken help me out.
p.s.is 250 installed for an integra front brake conversion a good price?
rotors are the same size, but teg calipers are a little bigger, and the teg uses a 1" MC, while you probably have a 15/16" MC. In all honesty, I don't think that is worth it. It isn't much of an upgrade. Your braking will be better, but nothing major. I would look into a big brake kit.
You could also invest in some stainless steel brake lines and better brake pads.
Discussion Starter #4
thanks for the help i don't think it is going to be worth it either. i am just going to change my brake pads then.
