1 - 8 of 8 Posts
I have a 95 Del Sol with a 1.5 and it had started to idle all crazy, up and down constantly, just revs up and down almost all the time it is not in gear. Any idea out there ?
It sounds like the IAC Valve to me. Its a valve on the back of the intakemanifold that is held on by like 2 or three bolts. They go bad everyonce and a while. They are kinda pricey though. I would try to clean it out with brake cleaner first. They can get gummed up.
i get that also i thought it was because i tapped into the vacuum line for a gauge. But ill look at the IAV valve. My father owns a NAPA so it shouldn't be to bad
check two things first before you go replacing parts.... vacuum leaks and check your coolant level. low coolant will cause idle surge
Link in my sig. read it and enjoy a purring idle
My b16 del sol was doing the same thing. I Sprayed carb cleaner in the intake manifold and cleaned the carbon off of the plates and it stopped
if its smoking badly after shutting off the car, or you smell an awesome burning smell then it could be a bad head gasket, which is what the problem for me was. if not, probably your iacv.
1 - 8 of 8 Posts
