I bought a temp sending unit for the gauge on my Si. I pulled out the old and started threading in the new.. it got a little tough so I backed off and took it out. Looked at the hole and saw that it was freakin stripped and that the sensor was the wrong damn size. So how much am I looking to spend to get this one fixed????
try to retap it urself if u trust ur self depends on how damaged it is.
try not to get so much shavings into the cooling system but u should be fine
teflon tape, works wonders but you should try and rethread it yourself. then get the right size and be carefull with it.
