hi i am goin to try to install dc 4-1 ceramic headers on a 2001 civic coupe this weekend. I posted this in the civic forum but no one responded so im trying some other forums. Has anyone installed headers by themselves before?? is it hard?? Any basic information would be helpful....thanks..
A header is about the easiest mod you can do. Unbolt and bolt back on again. Make sure when you loosen the bolts from the original exhaust manifold to spray them down with WD-40 before. Also when you connect the header back up to the cat. make sure not to tight one side all the way but to get both bolts on and then tighten them alternately (like changing a tirel). Take your time and read the instructions if you have any doubts. Good Luck!
