My friend tried installing my DC sports header but 3 of the bolts connecting the downpipe to the cat converter are badly rusted. 2 bolts connecting the downpipe to the main header are also rusted and he couldnt get them loose with penetrating grease. Do you guys know any other good products that can loosen these bolts? Thanks.
pb blaster and you should be able to get it at your local part store...spray it on let it sit for a bit and try to remove the bolts. if it doesnt work the first time try it a couple of times it should be able to break the nuts
For mine i just used good ole WD-40. Thing was rusted pretty bad but the two piece header finally came apart with a little muscle a couple attempts and a very long mess of extensions. The new header was even nicer, it made me smile when i tried it out for the first time.
