overcomplicated much??? lit up all the time?? run the wires to a 12v + thats on when the key is on, turn signals? splice them into your turn signal wires, yes if you tie into a honda turn signal circuit it CAN but might NOT change blinker speed, my guess is that you want the HALO's on with the driving lights ( corners, etc) as well as the headlights, i would tie the halo's into the corner lightsWhat do you want them as? additional turnsignals? lit up all the time, but only with the car on? on with the headlights?
If you want them on with the car, you need a relay hooked to your ignition. If you set them up with your signals, be aware that they wont blink as fast , rather they will be somewhat slow. You can combat that by using LED lights inplace of the bulbes, because the less power needed for the signals, the faster they blink (they run off a relay and capacitor setup)
