I'll be hitting the Honda/Acura wrecking yards looking for some misc. parts and if the Type-S header will fita C27block, I may give it a try.
Sad but true. I wish i had the money then i would upgrade my car to the newest model every couple of year.Tofu_V6o4 said:Hehehe, uciaccordv6 our cars will be oldskool in a few months alos kaka..
No aftermarket headers whatsoever for the 5th Gen V6...4star* said:if you are in need of headers for your car (C27A), go get your stock exhaust manifolds(headers) ported and polished. You will get better gains out of that than you will even if the CL-s headers would fit for your car.
do they make 5th generation accord V6 headers?
good info and way to dig!:btuI'm new here, but I have a 95 accord V6 C27a and the headers that do work for the car are OBX-r off of a 1990 Acura legend, and you can also use the lightweight aluminum crank pulley of of a 1999 Acura CL, and you will get some gains(17hp on dyno), the reason I know this is because thats what I've used on my C27a.
"I'm new here, but I have a 95 accord V6 C27a and the headers that do work for the car are OBX-r off of a 1990 Acura legend, and you can also use the lightweight aluminum crank pulley of of a 1999 Acura CL, and you will get some gains(17hp on dyno), the reason I know this is because thats what I've used on my C27a."I'll be hitting the Honda/Acura wrecking yards looking for some misc. parts and if the Type-S header will fita C27block, I may give it a try.
i dont know anything about the new generations but it you go to google.com and type in you problem in the search bar you may find an article that will help you out a little biti have a 2007 accord hybrid which i shipped to Africa from Seattle. I have a fault reading "Pressure Control solenoid c performance or stuck off" P0796 fault code. Problem is the dealer's here do not do the hybrid so are lost on ideas. Can anybody explain the problem to me and also a possible fix. any suggestions can be sent to [email protected]. would appreciate the help.
