Wierd thing happened today...
..driving down the road, went to turn on heater, blew out cold air...
.then noticed oil temp was all the way up. Pulled over, oil was at least a quart down, and she drank a lil coolant. But I drove again, the heater Started working as soon as the Oil temp went down...can someone explain that?
Also I might mention that I have a wierd short (bad ground maybs) in the dash, the light cut out @ random, and my speakers cut out @ random..
Any help...B18, almost 300k, due for an oil change.
Its just your coolant, honda heaters do not blow hot air unless they have coolant... Fill it up and you will be fine...
