OK folks. When I bought my car the heat didn't work. I looked at the Service manual on redpepperracing and saw how the heater valve work. I opened the cover under the hood and manually moved the rod to the heat position andit worked fine. So it appears that the heater control rod isn't being moved by the air mix rod. How hard is this fix? I am unclear on whether or not you have to remove the dash to fix this.
