While going for a slight thrash the other day, the check engine light appeared on the dash. Owner's manual says this means a malfunction with the emision control system.
Car has a glitch around 4000rpm, and when getting on throttle after going round a corner. Also, engine dies 4-5 times moments after starting, when the engine is warm. Cold starts (15deg weather here in NZ) is fine. Car is booked for Honda dealership next week. But I wanna know if anyone has had similar probs.
Could it be spark plugs (3000km old)
Oxygen sensor?
Major?
THANKS!!!!
JD
there's a thread around somewhere.. probably in the civic forum, that tells u how to get the code for the check engine light... start there and tell us what code it's throwing..
