Any1 had that problem b4? my 92 civic is throwin (Code 1) and (Code 43) n as im concerned code 1 is o2 sensor and code 43 is fuel supply system, first i got code 43 then after awhile i got code 1, when driving and i hit the gas it seems like it doesnt want to go anywhere until like 2 seconds after it pulls like it should in the 1st place.. now ma question is how can i get this problem solved ill apreciate the help!
:confused
Well your o2 sensor probably needs replacing...and you should check out your fuel system.
It could be a bad injector...failing pump...fuel filter?
