Need help troubleshooting 2000 Accord with h22a swap. It is converted OBD2 to OBD1. How do i pull the codes if i have an OBD2 port with OBD1 ecu? I can not get ahold of the guy that did my swap cuz he moved out of state. It was done 6 years ago and have never had a problem out of it but will not start (is turning over) and im not getting any spark to the dizzy. Please help me out guys.
Check the Main Relay Harness Under the Dash. Can you hear the fuel pump priming? Do you have fuel pressure? If it's not the relay then you have some other problems that are more directly related to fuel delivery. You can also check for spark by checking plugs etc. and especially the distributor rotor. As far as the codes, if you don't have the obd1 port you might be kind of screwed there...not sure, if you have a scanner I would try it. On ob1 honda there's basically a wire set that you would jump and then scan it, but I have no idea what your wiring looks like.
